I'm doing a HG and slipper replacement and resealing timing chain cover and oil pans. Before I removed the head I had the crank at 0 TDC and the timing marks on the cam gears as per the FSM and marked one link on the chain next to the dot on the cam gear. However while wrenching around the cam gear with the chain slipped down into the timing cover it wasn't tied tight enough. I figured oh well I'm removing the timing chain cover too and I set it right when I have it off. The FSM talks about a "bright link" on the chain I don't see it and have no way to tell what link should be in line with the key on the crank. When I have everything set with the cams I can move slack to either side of the crank gear. Do I need a new chain with the correct "bright link" mark on it?
Many thanks in advance.
George
George
