I read through the FAQ with the info from Safari4x4.com and read through all the other threads I could find. Also read the FSM and my Haynes manual. Looks pretty straight forward (once I get a timing light). And I'm hoping advancing the timing a bit may help with my sluggish 80.
Here are my 1/4
questions:
1) Any recommendations on a timing light (is it worth getting the fancy digital deals and, if so, why)?
2) Given that my idle is not at 650 (I'm working on it though - currently about 800 [EDIT]), how do I adjust for having a high idle?
3) Everything I read says that 3 degree is correct/factory. However, the FAQ (from safari4x4.com) states that I should check the timing before starting and it will probably be around 10 degrees. Then I should enter service mode by shorting the E1 and TE1 terminals on the ECU service plug (PS firewall) and check again and it should be 3 degrees. Then I should loosen the distributor bolt and advance the timing 6 or 7 degrees. Then turn off the engine, remove the ECU short and test again and it should be between 0 and 16 degrees (huh?
). Then after test driving it says to adjust as needed to avoid knock but that anything above 10 degrees is too much for this engine.
So my question here is this: I understand there is a difference between the service mode and non-service mode, but how do I go from a start of 10 degrees under ECU control, to 3 degrees in service mode, to 10 degrees in service mode (advance 6 or 7 degrees from the service mode start of 3) to 0-16 degrees under ECU and a warning to stay below 10 degrees under ECU control? Isn't this where I started??????
and finally
4) In the above FAQ instructions, while in service mode, it states I should loosen the distributor bolt and advance the timing. How is this done? If I read the FSM and Haynes correctly, I do this by simply rotating the distributor?
Jeeez, I think you guys are going to revoke my 1/4
status after this. I'll be the only 1/8
on mud.
Here are my 1/4
questions:1) Any recommendations on a timing light (is it worth getting the fancy digital deals and, if so, why)?
and finally
on mud.
