Tilt Wheel Loose
Anyone ever had the tilt mechanism loosen up so that there is about 1/8" to 1/4" of up and down play in the steering wheel? Will the airbag prevent access to the mechanism?
Thanks,
Grant
I am having this exact same problem. Seems to have developed over the last two weeks. I can move the wheel up and down about a 1/4" after the tilt has been locked. I have tried putting the wheel in a different position than I am used to and it still does it.
Search doesn't reveal much help on this particular problem.
Any help would be much appreciated as this is a very annoying problem.
:cheers:
If this was a Saginaw column, I'd know how to fix it !
But a Toyo is not one I am familiar with ! :frown:
Does the FSM show any good pics ? On the Saginaws ( primarily GM's ) the tilt housing pivots on an aluminum piece that is held to the metal tube, or mast jacket, by 4 bolts.
These work there way loose over time, especially if you tend to pull yourself up into the seat via the wheel ! :doh:
Might be worth a little investigative disassembly :D of the column covers to see if you can see the tilt mechanism at that point.
I am curious to see how this works out for future reference & generaly mechanical nosiness. ;p
Britt
Edit : best pic I have found so far, and it still doesn't tell me a lot ! Here
Thanks for the tips. I guess I'll consult the FSM when I get home and see what's in there.
Can't imagine its anything too difficult to fix.
I have the opposite problem, kinda. Whenever it gets really cold, my tilt mechanism won't easily unlatch like it does when it is warm. The column sticks in the upright position, and you have to push up a little bit on the steering wheel before it will unlatch and then can be moved to the down position. Anybody got any ideas on how to fix that?
