Tie Rod Question
San Antonio TX
This may sound like a dumb question to some of you guys but, I'm about to start tearing down my 40 axle for my mini disc conversion and I got the tie rod for a mini but, there is only one and there are 2? on the 40 . SO, do you just do away with the 40 rods alltogether and just run the mini tie rod from the steering arm to the other arm on the P side? And then attach your steering dampner?
Thanks
Poser,
thanks for quick response but, in one of the conversion articles under the tech section it says to use the mini tie rod.... Not a huge deal I just need to know which ones to use and how to reattach...
Poser,
Please point this out....
Again,
Look at the mini truck tie rod and the Land Cruiser tie rod, you will see the differences.
A mini truck tie rod does not have a provision in it for attaching the link from the steering system to the tie rod, like the Land Cruiser does.
In Mike Robinsons article under the parts needed from the mini line 3 says to use the tie rod from the mini, Jeff Fretwell's article at the bottom says to use the mini also....
I do see the difference in the two rods but somewhere I also read that the TRE's on the LC will not fit into the mini arms as they are too small but, You can use a shim from a starter? I believe and with a little manipulation it bolts right up...
Ok-
So they are using the piece that the steering stab. mounts to, in order to make it 'work' with the Land Cruiser system.
I guess if you have a known good Land Cruiser tie rod, I would install the starter bushings into the mini truck arms and use the Land Cruiser tie rod...but that is probably just me.
The info on this can be found in the FAQ.
I've been debating both ways and not sure if one is better than the other. If you use the mini tie rod you still have to use the other steering rod? from the 40 correct? So I may just stick with all 40 parts since I just replaced all of the TRE's and the rods are good and straight on the 40 and I'll just buy the starter bushings....
Thanks Poser,
If anyone else wants to throw in their .02 feel free
Someone out there makes the correct hardend steel shim for the TRE. Check Manafre or maybe Cruiser Outfitters. Seems I paid $29.
Lane
I take it you don't have the correct LC arms for the mini-knuckles?
Sell all your MT stuff you can't use, and keep it all LC...
manny
Manny, didn't you get the 4x4 labs hi steer? If so, Luke just put the 1 ton TRE on mine. :banana:
Currently running late LC arms...they match the wide pattern MT knuckles.
Can't go wrong w/1ton = More Beef for less $
met Luke at Rubithon last year, super cool fabricator...looking forward to his improved arms design :D
Manny, when you do that swap, let him know how high your spring packs are. The orignial arms I got from Luke didn't have a high enough offset to handle the FJ60 rears I'm using. He rocks though, He shipped me the others out and said to just wait till I swap them out to send him the old ones. Later
there must be some differences in the arms or tres i did my 2 69s with mini discs and the stock tierods bolted right in when i did my 70 i used a later model tie rod because the holes in the arms were bigger also mini. just dont know what year the mini stuff was from so there may be and upgrade there to larger tre,s not sure but with toyota i have always been able to cross fit most parts good luck
i went out and looked i used the fj40 steering arms on the toyota knuckles both 69s and used the stock tierods so everything bolted right up no problems hope this helps good luck
Are you saying that you used stock 1969 steering arms on Mini truck knuckles?
Just trying to follow along here.....
yes i dont know what year these were from i just got them from the pile of parts but the 69 arms bolted to the mini knuckles and both trucks have the stock tie rods im learning photos here so will try pics sat i didnt like the double arm on the drivers side and didnt want to cut it off so i tried the 40 arms and they fit fine hope this helps if i figure out the parts hopefully this will make it easier for some one else if i cant do photos on mud maybey i can send them to you poser if you dont mind thanks
I think I will use the stock 40 rods and use the bushings to tie it all together. Sounds like the easiest way for now.
i geuss i have to figure out why this works the discs and master areoff of mini trucks and i used toyota steering arms and it all bolted up thats why i couldnt figure why everyone is having so much trouble with the tie rod i looked at your link will check measuerments with yours thanks
