I was installing my tie rod ends and due to faulty torque rench, i overtorked one tie rod end to the point to stripping the nut. i managed to get another bolt on there, and it torqued down fine with my other torque rench. but it seems that the hole is now at the top of the castle nut (ie, it seems like the tie rod bolt streched about an 1/8"+).
My first reaction is to replace these tire rod ends ( i actually found that Advanced auto sells each one separately). but i was curious of how bad it was, and how tire rod ends usually fail? if they are torqued down to spec... 67ft/lbs, they should be ok???
Second, does anyone know if Early cruiser (drum brake) tie rod ends are interchangeable with late (1981/min truck) ends?
thanks.
thanks.
