ok did my tie rod ends this weekend. I did the relay rods last wekend. Before I go get an alignment I have 2 questions
1. the fsm says the standard total length of the tie rod from end to end is 47.51 inches (I checked Toyota's math on the metric conversion). My tie rod shaft not counting the ends is 45 3/8". It is physically impossible to adjust the tie rods ends so that they each extrude less than 1.5" from the tie rod. Therefore the FSM adjustment is impossible since the minimum length is roughly 48 1/2""). Is the FSM wrong or is my tie rod shaft too long?
2. Both my tie rod and relay rod are slightly bowed/warped. I can get the tie rod ends to slide into the steering arms without issues? Is it important that they be straight?
