ok.. so basically use a flat square of steel on the bottom side of the plywood. The tie down bolts thru the wood and the steel plate correct?
How large of a plate?
Getting really technical, a shape with rounded corners will be less prone to tear out than a square shape with 90° corners.
Size of the plate depends on thickness & type of wood you're attaching to, size & type of tie down, as well as how much of a load you expect the tiedown to have to take.
if you are using the tie downs to secure crap on top of the drawers...You may get away with using large diameter washers with an adequate bolt. that is what I did and works for me.
i did the same thing, just finished the project this weekend.
