I just got the thunder ac6 charger and i have to say the directions are less than user friendly. I would appreciate any help I can get.
I am using this for NIMH and NIcd batteries. I am not sure what settings to use.
I am using the Auto function but you still need to set a few functions.
On the discharge, charge setting what Amp setting should i use. Also is the the amount of amps it discharges at or is this what it draws it down to.
On the charge setting what amp should I use? I am charging a 6 cell Nicd 7.2v and a 7 cell NIMH 8.4 volt. This one uses 1500mh 2/3 amp cells.
Do I need to discharge each time or just once in a while?
Thanks.
Thanks.
