Does the TO bearing need to be pressed on the clutch hub? I checked the FSM and it has one of those "eyeball" pics and says "inspect for wear". I have a new TO bearing and new hub and the fit is very tight....but I also have a press.
Here is a great trick for installing bearings of any type. Heat them in oil, any very clean oil wil do, but prefably something heat resistant like motor oil or gear oil. You don't need to get them super hot, only hotter than the shaft they are mounted on, 200 deg, is usually way more than enough. Take the bearing out with tongs and slip it on the shaft with a pair of gloves. The closer you can do this to the shaft the better, it cools off less. If the bearing doesn't slip right on, quickly take it off and try again. This method has the advantage of eliminating any damage to the bearing. Never try this with a torch, you will get the bearing too hot. You can also do the reverse with a bearing that has to be mounted in a case. Put the bearing in the freezer and leave it for a few hours to get nice and cold. Drop it in the case and let it expand. If you are in a hurry you can use dry ice, but only chill it for 15 MIN MAX! If you leave it in the dry ice too long it will change the properties of the steel and the bearing will break. If you are cooling a bearing in a humid environment make sure you wash it down with some oil or the condesation will cause it to rust.
