throttle cable adjusting?
raleigh, nc
I have a problem when i stop it feels like a lurch forward a little bit like its downshifting, only after i come to a stop. Im thinking it may be my throttle cable so i adjusted it a little, drove it and their was no change so i adjusted it the other way and no change. So i guess my question is should i be adjusting to tighten the cable or to give it some slack? before i adjusted it didnt seem tight. thanks
blake
well i couldnt fix it before it got dark so i just put it back in the position it was in. doing more searching in the fsm though and i think maybe my idle is too high. could that be the problem? fsm says in should be around 650 in N. im at around 1100 maybe 1200:eek: is that bad and how the heck do i fix it?
thanks for pointing that out 80t0ylc i just figured you guys knew me by now ;) its a 95 and the PO put in a cold air intake (which i hate) and thats the only mod. thanks
blake
The high idle is typically caused by a cracked air intake hose or dirty throttle body. In my case it was both. Now mine purrs at 650+/-
thanks gotmud. ill check that stuff out today and maybe wait for the weekend to wrap my head around this possible throttle cable problem. thanks
blake
