Throttle Body Noise?
Tucson AZ
I was helping a friend diagnose a ground issue on his 80 the other day and I noticed a strange 'hissing' noise while my truck was running with the hood open.
I finally spent some time to try and find the source today. All the vacuum lines look ok and while diagnosing I noticed the noise went away with mild pressure/contact with the palm of my hand on the throttle body.
I have not removed the throttle body and cleaned it and this engine use to be almost silent except for the injectors clicking away.
Any ideas?
maybe the bolts that connect it to the upper intake are loose?
I know you stated that the throttle body has not been removed, but it would be a quick check (there are 4)
One of the easy ways to find an air leak is to use a spray bottle full of water. Hose the suspect area, as the water gets sucked in the sound will change. When you find the general leakage area, let it dry for a minute or so, then spray a smaller area, until you find the spot.
