throttle adjustment
Dalton GA
I'm having issues with idle engine. 2F engine
Recently changed my fuel pump and fuel lines.
Able to start the engine and idle fine. Once i start driving then engine stops at first traffic light bc not idling properly. Adjusted the idle screw and seemed to work for a while.
now the problem started again and fiddling with idle screw does not fix it. Does the same without air filter in place.
Any advice appreciated.
Make sure that your fuel cutoff solinoid on your carb is still plugged in a you hear a click when the key is turned.
