Three questions
Newberg, Oregon
Rookie here; WHere can I get an FSM?
Where is the birf grease fill hole?
And what type of grease do I use?
Thanks all:confused:
1-Toyota sell them or you may find a used on online if you are lucky.
2-It is a square plug on top of the knuckle, you may have to turn the wheels side to side or better yet remove the wheel for easiest access.
3-Moly fortified grease. Stick a screw driver down the hole first to see what the grease looks like and if it it runny from oil seal failure and diff oil contamination.
Ps. Search is your friend.
Try SOR
