three lights on in cluster
Michigan
AT light, Brake light, and low battery light all came on at the same time. It did this last month and the voltage regulator was bad. Had the alternator rebuilt and it worked fine for 30 days althought the voltage gauge didn't seem to go up as high as it did before this happened. All electronics worked fine. Should I be looking for a problem somewhere other than the alternator? Could a problem elsewhere cause the regulator to go out? When I got it home I turned the engine off and on a few times and one time the lights went out and it was charging again. By the time I put the dogs in the house to take it for a test spin, the lights came back on. Any ideas?
Thanks, and I did a search.
I checked all connections and they were good. I just pulled the alt. last month and cleaned everything up before I reinstalled the rebuilt alt. The rebuilt unit did act a little different that before it went bad. The gauge was always rock solid even with all lights on, heater, defroster, brake lights, etc. After the rebuild I could see the needle bounce around a little when the turn signal was activated. The needle didn't go up past the middle as far as it did before. It was above the middle mark, but not quite as high as before. The alternator is off now and I guess I'll take it back to the guy who rebuilt it. I am just curious if there could be another problem that is causing this to go bad. At least I'm getting pretty fast at removing the alt!
Anything but OEM seems to be iffy as far as 3FE alt's.
I got about 3 years out of a rebuild (not too bad for the money I guess, but not exactly awe inspiring reliablility. Then I put a NAPA unit in that was bad right out of the box.
is this cruisers very own three amigos?
