Thread size
94 1fz does anybody know the thread size I believe it's NPT pipe thread. From what I measured .625 in. It's the first sensor from the front of the head below the intake manifold. I took these off with no issues they will not go back on after it came back from the machine shop so I don't know what happened more than likely they bang something against it.
I don't know the thread but just in case you are trying to put it in the wrong spot here is a pic I took when I rebuilt mine. I had issues with a few of mine from the paint I used in the engine as well
cant remember the tread but metric straight as the seal is the washer. tapered uses the threads. 14mmx1.5??? or 12mm i'd start down the metric straight thread direction first
Thanks for that picture david it's the little sensor head closest to the timing chain I was able to borrow a tap from a good friend size is 16 by 1.50. At first I thought it was a pipe thread but a closer look revealed it's a regular thread. I have removed all these sensors before I took it to the Machine Shop all the threads were nice, looks like they must have banged it somewhere.
