thread mesaurements
semlin
curmudgeon
Mod Emeritus
north of 49
does anyone know the thread measurement and appropriate length on the 12 mm (socket size) chassis bolts you would use when rigging a diff breather hose extension using p-clamps? I am thinking 1/2 inch depth but my Toyota dealer does not know what thread.
That would be 8 x 1.25 mm.......
Length could be around 15mm or so.
:beer:
Semlin,
If you are using the instructions that were posted a while back, you will need very few 8x1.25mm bolts. Most are already clamping something and you just need to add the P-Clamp under the factory bolt.
I believe you will find a couple that are in threaded holes under the hood but are not holding anything. I removed and used those.
-B-
Get a thread gauge- you might have to hunt some to find a metric thread gauge- but I think most boltss on Cruisers are either 1.5 or 1.25 (fine). Correct me?
David,
Toyota does not generally use 1.5mm threads
The only exception that comes to mind,as I swill a Boddingtons, is lug studs..............which are 1.5mm.
