Thrashed my front defector
Colorado
Wheeling in Montrose and I did this to the defector #30 here:
http://www.sor.com/sor/cat090.tam?xax=15636&page.ctx=cat090.tam
Now its leaking diff oil. The seal looks good. Should I just replace the deflector or should I replace the seal or other parts to stop the leak?
I assume I can still get the deflector from the dealership. Should the pinion that sticks out of the third member be loose? I can move it up and down and left or right about 1/4 inch. See the picks of my finger on the pinion.
Thanks.
That nut that holds on the pinion flange also locks the pinion in place. Without it the pinion will walk all over the place.
Replace the seal and the seal protector, or just replace the seal, those protectors are more for stopping grasses from getting caught up in the pinion flange and working their way into the seal. With as often as wheelers are likely to be in their diffs it is almost not necessary at all..
But if you want another one, I'll stick one in the mail tomorrow. PM me if you want it.:)
Ed
Background :D
