Thoughts on oil light....
Mt Pleasant SC
Hey,
The oil light on the :princess: 's Lexus has come on. It has been 3000 miles since the last oil change. This happened last time... There is no oil on the floor in the garage. Any thoughts as to what might be causing this? :confused:
Emmett
Hey,
Emmett
It could be burning it w/o much signs. The CATs do a good job nowdays and you won't notice much blue smoke except maybe a little at startup when the CAT is cold. When I purchased my LC it was doing this (though much more extreme than yours) and I didn't notice much was wrong other than oil consumption.
Hey,
Emmett
Did you check the oil level? If the oil level is low, then the indicator will light.
The engine burns some oil. And, sometimes, the oil light just goes off.
The most important thing is to check the oil level, though.
You'd smell it if you were burning 2Qts in less than 3K miles. You can smell it long before the exhaust makes smoke.
I just replaced a valve cover gasket that was leaking about +/-1Qt in 3K. No oil spot on the ground either. Instead, it was leaking onto the exhaust manifold and burning off. I could smell that too.
How low is the oil, how many quarts to fill? The float sensor that turns on the light on has been known to stick, fail causing the light to come on when not needed.
Mine always comes on when I'm 1 quart low. I go through about 1 qt every 2k miles, so when it comes on I just dump another quart in. Am I running a risk that it will stick and my oil will go w/o my noticing? Probably. However that little float sensor gets a pretty good workout so I'm not that concerned. I'm just shy of 200k miles, and this rig only has to last me one more year before it can be taken down for some much needed mods(i.e. heart transplant).
Ary
