Thoughts on Death Wobble
here
Next time it happens to you out of the blue, on a rig that has run fine,
take the MTR's off. burn em, put radial hawgs back on.
MTR tried to kill me, fawkin DW at 50, and I mean like holly s*** DW. All areas of possible concern checked out 100%, even tried toe in at three different settings to see. Actually wobbled the worst when set with most toie in.
Wobble was happening only very ocasionally and over the same railroad tracks or little whoopy section of road. RxR at 35mph Whoopy section at 50mph.
After test driving 3rd toe in setting I was getting to where I could feel the difference in steering when DW was gonna happen if it hit whoopy bumps.
Couldn't figure it, everything checked out, Mudrak suggested a method of checking toe in and that there was possibly a bad tire.
When scribing tires to check toe in again noticed that one tire had flat spot.
one bad MTR being moved to spare position.
One fj40 driver fully expecting DW to accur at every bump.
I had something similair happen to me but not so severe as yours. It tuns out the tire carcass (brand new tire) was not nice and round. After balancing about 5 times at 3 different places I took all 4 tires back even though only 1 was bad. These were BFG's and seems I am the only one to ever have this happen (according to the tire shop of course). Anyway, a high speed wobble can definitely make your pooper pucker.
DW on the 40 is what is it, like the changing of the tides and the rising and the setting of the sun:meh:
I had the DW bad for a while, knuckle rebuild, bearings swap and new TREs paid huge dividends. It still does it every now and then, but ain't bad at all
Each vehicle is different I guess - I have been running BFG 33 x 12.50 x15 MTRs almost since they first came out and I have at times had some pretty sloppy steering systems for all the usual reasons. I sometimes find myself herding the truck around instead of steering it as a result and it makes it tiring to drive but I have never had death wobble except once a long time ago with bias ply Firestones. It turned out the tread was still good but the carcasses were shot.
Mine was real bad and pretty consistent at mid to high speed. It got me to do a complete knuckle overhaul that I probably never would have done till I broke something. In the end, after having my Baja Claws balanced for the 3rd time, my tire guy pulled the tires to find a 2 lb hunk of rubber, left from the mold, floating around in one of them. It must have finally separated after a few thousand miles. Mystery solved after 5 months of head ache!
