Thinking of buying gx470
SHERMAN FJ62
Charlestons' King of Cruisers
charleston
I am thinking about buying an 03 GX. Wanted to know what is the largest recommended tires for this truck. I also wanted to know about people installing a ARB bumper on this truck easy to do without a bunch of mods to the truck.
Thanks
If lifting the largest tires you can fit are 33s.
Stock ride height is probably 32".
When I was at the stock ride height running 31.5" tires I had to use a heat gun on the front fenders to get rid of a little rubbing but I'm also running wider / more neg. offset 18" wheels so you might not have to trim at that size.
As far as the ARB bumper you'll have to cut the GX to make it fit.
I always wanted one of those BAD A.. ARB bumper actually now that I think of it I bought my GX to get one of those thing for it until I found out it will be so heavy junk of metal + it Ain't the ARB pumper unless you drop a another 89 or so pounds of winch in it and then to carry all this weight I realized I need heavy duty coil over front suspension than what good does a ARB pumper good for if it doesn't have punch of driving light on it after all said and done it was right a bout $5000.00 .but then thank god I woke up :)))
just something to consider.
