Thinking Hydro Assist
Germantown, MD
Did a search, found some very useful info. I feel that I really should get this done before pulling trigger on the bigger tires and other stuff. The plan is to port my OEM box to take the hydro assist RAM. Any recommendation for the RAM (brand, etc)? Any one has a picture of a ported OEM box of an FZJ? I have seen many others but the FZJ.
Thanks a bunch :cheers:
Riad, we have ported the 80 box and it is similar to the minitruck stuff. However I am not sure if the 80 pump is going to be happy doing double duty. Also, on the 80 it really depends on where you are planning to put it. The stroke required is longer than most applications. I believe it was 10" last time we measured. The obvious place I think is on the back of the axle onto the tie-rod. We have done one setup on a 80 axle in a tacoma where we tried to run it where the steering damper used to go. That did not last very long.
PSC stuff is good quality. Get good hoses and fittings, but for now the 80 pump is still the problem.
We only sell PCS we have tried them all
we sell complete systems with the porting of your box every thing matches
so the system is not slow that is the problem when the system dont match we get people all the time asking why the steering is so slow.
I need to checkout your website. I was hoping that some one has a full kit. Appreciate the info, I might contact you as soon as I am done with my research.
Thanks :cheers:
Hmm, so I guess that means I could not mount the stroke where my stabilizer is right now. I did not know the about the issue with the pump. I guess I would eventually find that out :D, thanks for providing that info. So any remedy for the pump? I haven't thought of replacing the OEM pump, I don't even know if that can be done easily.
I would immagine that if a solid frame mount were fabricated the ram would work fine with one end connected to the current stabilizer TRE. lots of trucks do similar.
That is not the problem. It is the angle of the drag link that is the problem. When the PS droops and the angle is at it's worst the force of the ram is not in the same direction as the drag link and it bends it. Granted this was on a truck with lots of droop, but still was not the ideal case.
I mounted a PSC pump and blanked off the factory pump. That is not a recommended solution. It worked but not ideal.
Is there any way to increase the flow and/or the pressure of the OE pump? Sorta like the modified Saginaw or some of the European mfg'd pumps?
