Thinking about some drawers but?
Oregon
But I got a OEM subtank installed.
Is there drilling involved? Would I have to take down the tank first?
Thanks
Custom drawers or the African Outback setup?
I think on the Outback system you remove the 3rd row hold-downs and use those to mount the frame.
I used the same points for my homebuilt, but I'm sure some folks drill out new spots.
I've been working on a custom setup with a fridge. Stop by if you are heading North through Salem to check it out.
I'm going to go with compartments and tubs though. Using the 3rd row seat bolt holes to anchor it in. Sort of system of plywood shelves that will fit a fridge and some large tubs.
Have fun
If you do need to drill just use a depth gauge to stop the drill going through too far.
There is still a bit of room between the floor and the top of the tank. IIRC, at least 3/8 - 1/2 in. because of the pressed ribs in the floor.
My christmas present to myself (and the cruiser) this year was a Black Widow storage system and I had exactly the same thoughts regarding the sub tank.
I custom-built my drawers in 07/2006 and used the four of the 3rd row seats floor anchors to secure them with U-bolts. It hasn't moved a bit since and no drilling was ever needed.
Same as alkaline. Mine has no attachment points. It fits snug, is heavy, and is wedged in there. Even in a roll over it is not going very far.
My 80 never came with third row seats so using the rear seat mounts as a attachment point was never an option
