thermostat ?
CANADA
00602-17620-440THERMOSTAT TRD LAND CRUISER 08/92-97 1FZFE ENGINE 160 DEGREES$85.00
is this better than the stock one in my 94, as i've heard the thermostats arent that acurrate...good...etc, or if i'm wrong whats the dif between this one and the stock one and would it be better to use, even with out a super charger
I hope that's a temperature guage you're referencing. $20 is a rip-off for a thermostat- $85 would be criminal.
-Spike
Not any better, but sure expensive. Was designed to help with Super Chargered engines, over heat problem they may have. Not neccesarly the problem with the engine getting warmer, but a good guess. You see TRD stuff is expensive. I would not put this in your truck unless you have a engine that is forced inducted and are in a really hot climate and have done every thing else to cure a Overheat situation.
IE, full cooling system overhaul, make sure your fan clutch is working, You have no head gasket problems. later Robbie
