thermostat, when to replace?
Oregon
Website
www.brian894x4.com
1995 F ZJ80 with only about 86K miles. No cooling problems, but I want to change out the green antifreeze for Toyota red and since I can't flush at home (apartment) I was going to have the dealer do it for me.
I thought about PMing the thermostat too, since it's probably original, but the dealer wants about $112 additional to change it out. Since I'm not having any cooling issues, is it worth replacing or should just I leave it in there for the next couple of years?
I wasn't sure how long the original thermostate typically lasts? Thanks.
Brian,
if you are changing the coolant anyway, just put in the new t-stat. It is very, very simple to do.
-undo the 3 bolts, pull apart and pull out the t-stat.
-replace w/ new one (tiny hole centered at top)
-the header heat shield is slightly in the way, you can unbolt or just bend the edge back to clear.
I wish you could DIY b/c it is so easy and not worth $112 extra.
Unfortunately, I need to flush the coolant and I have no place to do that, since I'm in an apartment. I don't think I'm going to waste the money replacing the thermostat right now. I can replace it easy it enough at a later date if I ever have too, once the coolant has been flushed and changed to Toyota red.
I really hate paying someone else to work on my rigs. Especially simple stuff like this.
blah blah blah
"I really hate paying someone else to work on my rigs. Especially simple stuff like this."
#1 - An excellent two sentances. Keep those thoughts & you will go far...your journey will not be frought with forking over huge sums for things done more fiscally responsible and you will learn many things about you rigs and yourself...
#2 My advice is pretty narrow scope and typically only works for me.:beer:
#3 If I paid someone $112 to change a thermostat I would simultaneously be posting a request for someone to come to my house and beat some sense into me.
#4 your concern of living in an appartment suggests you respect some limitations associated with your environment and I respect that...surely you have someplace you could go to work while at the same time accomodating the impact of your work?
#5 see #2 above:beer::beer:
Look, this is what I would do, "just put it off...."
Then about a month from now when it is HOT as "you know what" and you are out in the middle of know where, it will break down.
Then you will get out of your vehicle and start :crybaby: pounding your head on the fender , saying " why didn't I maintance my rig when I had the chance..."
Then you can pay some small town mech. three times as much to fix it.......thats how these mech.'s in these "out of the way places" make all of their money....towing, ordering the part, etc, etc.....
Yea, ...............thats what I would do.........."just put it off."...........:)
