Thermostat replacement.
Portland, OR
FSM says to "drain engine coolant" - will draining from just the radiator drain only drop the fluid level low enough to do the thermostat or do I need to drain block and radiator ?
"will draining from just the radiator drain only drop the fluid level low enough to do the thermostat or do I need to drain block and radiator ?"
Well im not so sure on that, I drained it completely from the engine block.Actually if I were you I'll drain it out completely.
Not hard to unplug the engine block you just need 14mm socket with long extension.
On other vehicles (haven't done an 80 yet), I don't drain the coolant unless it's time for a flush. If the coolant is fresh, just change the thermostat. When you open up the thermostat housing, the perfect amount needed to drop below the thermostat will spill out. Yeah, I know this is the ghetto way, but I never understood why you need to drain it so the coolant doesn't spill out. I don't think it matters where it drains from, so why not drain from the thermostat housing and save as much coolant as possible. Plus it saves time.
