I just did a headgasket on my truck and wanted to clean the cooling system as soon as I got it back together. I used a product called Thermocure. I have always been skeptical of flushing agents, but holy smokes this stuff works. I flushed the cooling system with the hose and made sure to remove the block plug. After flushing I filled with distilled water and the quart of Thermocure. I drove around getting it up to temp and let it sit for 6 days. Periodically I would start it up and let it idle to operating temp to keep it circulating . After those 6 days I flushed the entire cooling system again and was amazed how everything looked inside the radiator and thermostat housing, everything looked brand new! I put a little in the overflow tank and at the end of the 6 days you could see exactly how full The overflow tank was because the bottom of it was perfectly clean, but the top still had the 20 year old stains on it. The Thermocure removes rust and is biodegradable and doesnt have any harsh chemicals or acids in it, it's made for cooling systems. After doing the Thermocure my truck is running 179 degrees and if I'm hard on it the truck hits 185 on the scan guage. I don't know if this makes sense, but before the flush it took forever to fill the cooling system. The water was going in slow and burping took for ever. After the thermocure the water and antifreeze mix fill went into the radiator so fast and took 3.5 gallons extremely quickly. I burped the system with the engine running and it took hardly any time at all compared to burping it the first time. Like I said, Im always skeptic of 'snake oils' but this stuff blew me away. Amazon and Summit sells it and it has almost all 5 star reviews.
Summit Racing® EVAPO-RUST THERMOCURE SUM-TC001
