I was wondering what would be considered a complete engine tuneup. I have replaced and adjusted various things on my 93 and wanted to know what else could be adjusted, cleaned, or replaced for an all around better running and more fuel efficient engine. Of course some things were done while the engine was apart for HG replacement. This could be a good thing for the maintenance section in the FAQ if we could put something solid together so please share your tuneup endeavors.
What I have done so far:
New plugs, wires, cap, and rotor
New air filter
New fuel filter
New PCV valve
New EGR vacuum modulator (blue top)
Two new O2 sensors
Cleaned throttle body, pistons, and complete intake manifold, and installed an oil catch can
Sent the fuel injectors to RC Engineering
Had valves reground and shims adjusted
Adjusted engine timing to 5 degrees TDC
Adjusted throttle and trans cables
Thanks
George
New air filter
New fuel filter
New PCV valve
Two new O2 sensors
Thanks
George
