- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Improves Traction with the Flip of a Switch
MAUMEE, OH, Dec. 6, 2016 – Dana Incorporated (NYSE: DAN) has announced that The Ultimate Dana 60™ and The Ultimate Dana 44™ axles for the Jeep® Wrangler JK will be available with an ARB® Air Locker® option. This feature will be available on The Ultimate Dana 60™ axle at the end of 2016 and on The Ultimate Dana 44™ axle in the Spring of 2017.
The ARB Air Locker utilizes a pneumatically operated locking system located inside the differential. When activated, the system stops the differential gears from rotating, preventing the axle shafts from turning independently of each other. With both wheels locked into the rotation of the ring gear, the vehicle maintains maximum traction at all times. When unlocked, it operates just like a conventional “open” differential.
“The ARB Air Locker option allows the vehicle to be driven in a slower, safer, and more controlled manner, greatly reducing the likelihood of vehicle damage and environmental impact,” said Doug Wolma, vice president and general manager, Dana Aftermarket Group. “This gives off-roaders the traction they need, when they need it, all at the flip of a switch and all within the comfort of the driver’s seat. It’s the perfect addition for the serious off-roader.”
The Ultimate Dana 60™ axles, introduced at SEMA 2014, are bolt-in replacement upgrades for front and rear axles on the Jeep Wrangler. The axles feature:
The Ultimate Dana 44™ axle, introduced at last year’s SEMA show, is a bolt-in replacement upgrade for front axles on all Jeep Wranglers from 2007 to the present. Among the improvements incorporated into The Ultimate Dana 44™ axle are:
ARB Air Locker systems employ a 12-volt ARB air compressor (not included with Ultimate Dana 44 or 60 axles) designed to activate/deactivate the locking mechanism inside the differential. The ARB Air Locker features forged gears and an improved two-piece design that adds increased strength and durability. These design improvements have reduced the number of moving parts, resulting in a much firmer and responsive activation along with increased load bearing capabilities.
More information about the ARB Air Locker option is available at www.SpicerParts.com?utm_source=rss&utm_medium=rss, or by calling Dana Customer Service at 1-800-621-8084.
About Dana in the Aftermarket
Powered by recognized brands such as Dana®, Spicer®, Victor Reinz®, Glaser®, GWB®, Thompson®, Tru-Cool®, SVL®, Magnum®, and Transejes™, Dana delivers a broad range of aftermarket solutions – including genuine, all makes, and value lines – servicing passenger, commercial, and off-highway vehicles across the globe. Leveraged by a global network of 13 distribution centers, Dana’s dedicated aftermarket team provides technical service, customer support, high fill rates, and on-time delivery to customers around the globe. For more information, please visit www.dana.com/aftermarket?utm_source=rss&utm_medium=rss.
About Dana Incorporated
Dana is a world leader in the supply of highly engineered drivetrain, sealing, and thermal-management technologies that improve the efficiency and performance of vehicles with both conventional and alternative-energy powertrains. Serving three primary markets – passenger vehicle, commercial truck, and off-highway equipment – Dana provides the world’s original-equipment manufacturers and the aftermarket with local product and service support through a network of nearly 100 engineering, manufacturing, and distribution facilities. Founded in 1904 and based in Maumee, Ohio, the company employs more than 23,000 people in 25 countries on six continents. In 2015, Dana generated sales of nearly $6.1 billion. Forbes Magazine has again selected Dana as one of America’s 100 Most Trustworthy Companies for 2016. For more information, please visit dana.com.
The post The Ultimate Dana 60™, Dana 44™ Axles Now Available with Optional ARB® Air Locker® appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Continue reading...
- 35-spline, nickel chromoly steel axle shafts designed for higher torque, larger tires, and off-road punishment;
- A greatly enhanced carrier with Spicer® performance ring and pinion gearing;
- Massive SPL® 70 u-joints, exclusive to Dana;
- Full-float design for greater load-carrying capacity; and
- Upgraded, heavy-duty brakes with plug-and-play ABS.
- Increased axle tube thickness to 5/16 inch for improved strength, rigidity, and durability;
- Redesigned, thicker brackets with 1/4-inch steel;
- Nickel chromoly axle shafts designed for optimal strength and performance;
- Spicer® Life Series® 1350 u-joints with triple lip seals and full-circle clips for ultimate protection and retention; and
- High-strength nodular iron performance differential cover with a Spicer® performance gasket.
Related posts:
- Spicer® 1350 Series Driveshafts Now Available for The Ultimate Dana 60™ Axles
- Dana Announces Ultimate Dana 44™ “What’s The Diff” Axle Give-Away Contest Winners
- 2007+ JEEP WRANGLER JK RUBICON 35 SPLINE ARB AIR LOCKER
Continue reading...
