The right way
Austin, Texas
I'm building a 72 FJ40 and need some advice. I lived in California and started building it for rock climbing the Rubicon. Now I live in Florida and need to finish it for deep slippery swamp mud and soft sugar sand. It has a 5" lift, chevy power steering, chevy disk brakes, firebird steering column, 35 x 16 MTRs, trail ready rims, stock 3 speed, stock transfer case, stock rear, stock gears and stock F155 w/ headers. I plan on putting some 40 something super swampers my next go round. I have no power out of the hole now even on pavement. Can gears fix it? If I HAVE to go to V8 and new tranny, what is the stoutest and best way to go?:eek:
TLCA# 99458244
Guess the membership drive is working!!!! All I have to say is what I already said on the CCOT board. But you will get some more responses here. GL
And
Welcome:flipoff2: :flipoff2: :flipoff2:
Ed
TPI or TBI 350 - either sm465 or nv4500
i'd get pig axles for the rear and longfeilds up front for those 40" super swampers
regear it would give you more "go" ...i'd say 4.88's but not as high as 5.29's because then you have pinion snap issues...
whats trans. are you currently runnin?
There is no "right" way, just a bunch of opinions and speculation. ;)
If you HAVE to go to V8 and new tranny, then something with a granny gear such as 'Rooster suggested, although many will tell you that autos are the only way to go in the rocks now. You might also want to upgrade the transfer case to a newer style split case, or if an Orion/toybox/rocbox is feasable, you might want to look at those options as well.
So what I'm basically saying is SEARCH! :flipoff2:
Steam clean, and then "Rust Bullet"/"POR-15" the frame. Mud and sand in that salt air environment will kill it quick. Mechanically, I'd get a t-case saver, and like mentioned before, the inner axels.
Look up the Florida Land Cruiser club guys. They do a couple wheeling trips a year. I have seen them at Tellico (GSMTR) every time I have been there. they could be a good source for parts, and wheeling that doesn't include mud and sand.
Either way Have fun with it!!!
Rock crawling gears are not what you are going to need for sand/mud....so Toybox/rocbox/etc. would be a waste of money.....
If I were making a mud/sand truck it would have a small block and an auto for sure.
Good luck!
-Steve
