The rats moved in
Central Washington
Parked my 92 cruiser in our shop for a stint while chasing down some lingering issues (power steering pump/pulley replacement, CEL 25/26 EGR woes, rough idle). One day I noticed a number of tiny paw prints in the dashboard dust, and sure enough the rat's had moved in--little turds everywhere and a nest spilling out the back of the driver's seat. And to think I parked it in the shop to prevent this very thing...
Upon closer inspection of the nest I found a bit of wire. Unbolted the seat to have a closer look and it looks as though they've demolished a chunk of the wiring harness. Which would probably explain why I'm suddenly unable to shift out of park without using the shift override button, and why the reverse lights/dash indicator aren't working. The headlights, brake lights and turn signals still function properly.
Not sure where to go from here--do I need a whole new wiring harness?
Ouch. Your best bet is to find both ends of that connector and remove, disassemble the terminals at the connector, buy new terminals and crimper, rebuild that section. It’s not so bad so long as you keep all the pin-outs straight.
