Thanks Guys (Birfield repack)
Just wanted to say thanks to the contributors of the front axle repair guide I found here at IH8MUD. It was a big help since I had never done this job before. The pictures and tips went way beyond the Factory Service Manual. This was a big job for me as I did it alone. I replaced the Trunion bearings and also th wheel bearings while I had it apart. The wheel bearings were the worst I had ever seen and the trunions were so so but not too bad. The birfs were well greased and were in goodshape still thankfully. It appears this service had never been done before judging by the way things came apart and the condition of the grease and so on. This all took me every bit of 7 hours per side but I know it needed done and I saved lots of $$$ and its done RIGHT ! !
Anyways thanks from a newbie.
I own a 1997 fzj80 40th anniversary edition with 157000 miles that just purchased a few months ago. I ve always wanted a Landcruiser and really like most everything about it.
Now I have to replace the L. F. brake caliper rotor and front pads on both sides and hopefully that will be all till Spring rolls round again.
From
Getagrip in Kentucky
From
You should have replaced the brakes at the same time. I understand with money constraints though it is the same reason why I didn't replace mine when I first did my axle service.
Don't worry about the 7 hours next time you'll be able to cut that down the 3 easy. First time is always the hardest
Yep had planned on the brakes and had the new pads but got hung up on the L.F. caliper because the two outboard pistons were seized up and have to wait on the repair parts for this. Getting a rebuilt caliper today and also a rotor sine the stuck piston cause damage to the original one.
