I just wanted to attest, yet again, to the wealth of knowledge based on this site.
I'd been getting a CEL for a few seconds every couple of weeks for the last few months, along with a short stumble while accelerating just after startup. Last week, the light stayed on. Pulled codes 21, 83, 84, and 85. 21 being an oxygen sensor issue, the other 3 indicating TCM communication problems.
I'd replaced the O2 sensors about a year ago with non OEM (although they did have the correct plugs). My bad, I won't stray again...
Luckily, I kept the original sensors.
A little research found that early '93 models have an ECM (89661-60170) that's prone to these 83,84,85 codes and the only fix is a 'new' ECM (89661-60221, from later '93s and '94s). I found an ECM online with the updated number and had it shipped for $175. A 10 minute install on the computer, another 20 minutes to re-install the original O2 sensors, pulled EFI fuse for 5 minutes, and the CEL is gone.
Thanks again to Dan and the rest of you!
Luckily, I kept the original sensors. A little research found that early '93 models have an ECM (89661-60170) that's prone to these 83,84,85 codes and the only fix is a 'new' ECM (89661-60221, from later '93s and '94s). I found an ECM online with the updated number and had it shipped for $175. A 10 minute install on the computer, another 20 minutes to re-install the original O2 sensors, pulled EFI fuse for 5 minutes, and the CEL is gone.
