Thank you 'Mud (And Help...)
Guys, I just realized what a great resource this is, and am infinitely more appreciative of all the great info and support here. My little sister's 1997 Discovery has been giving her fits. 133,000 miles, s***e its engine 8,000 miles ago and has a "new" low mile engine. I have been trying to figure out what is wrong on various Rover forums and (seriously, not to bash them...at least not on purpose) it is absolute mayhem. They just throw out a list of five or six possibilities and say start replacing. Honest to god, I haven't gotten any good answers, and noone on those forums ever posts their solutions. At least that I can find.
So... I thought I'd throw this out to all who may have knowledge. I replaced plugs, wires are nearly new. It will start and run fine, and rev up just like normal. But, once you put load on it, it will bog down, and won't go above about 30 mph/1500 rpm. It also sounds like its backfiring/detonating in the air intake area, or manifold.
Things I gather it could be...
1-Dizzy: How do I test this?
2-Plugged Cats: Guess try to pull them out if all else fails.
3-Crank Position Sensor: Not sure where this is, and of course they aren't too clear.
4-Fuel Pump: How do I test this? (Squirts out of the Schrader valve when running, but not hard.)
Anyway, if you guys can help, great, if not I understand. I don't understand why everything is not easy to reach on these as everything needs to be reached fairly often... :)
Thanks all, Michael
P.S.- For those that may consider a Land Rover... '97's are god awful... :)
Actually, O2 sensor is NOT okay, but it was running right fine with it out of whack. Fuel filter I shall check. And sorry for bringing a land rover onto our Landcruiser forum, but I really haven't gotten any useful replies from the land rover guys and my mom is getting sick of schlupping my sister around. :). Thanks.
Is there a way to hook up a computer and run a test ? I would also say the mix is not right ? Can you take up the rmp slowly to/past 30 ? Where does it quit ? Thats how I found I had a miss and replaced plugs and wires - maybe a bad plug ? Pull wires and see what changes. Might be something along the lines of KISS. Again it is a Rover.
Well, I replaced the plugs last night and it ran better, but still bogs down any time its put in gear. I can get it to around 30 or 35 miles per hour by taking it slowly. Not past that though. The computer just says "misfire." I'm trying to change fuel filter tonight.
I don't have any idea what the values shpould be but you should test the ignition wires with an ohmmeter and the coil as well. ...you say they are almost new - but they are Lucas-built right? ...Nuff said. Also check at night for any sparks emanating from the engine compartment. I never owned a LR but I have several friends that have had Lucas electronics on vehicles and never heard a kind word about them.
...this was actually what stopped me from even thinking of a LR - then I came over to the predecessor to this board and found several people saying the opposite: "Don't just throw parts at it - find out what is wrong using the FSM." I've never looked back.
I know. I'm trying to get her to sell that piece and buy a 'cruiser. :). My parents had a '91 for all of our youth. That ought to be enough of a boost. Plus, mine, and theirs never had any problems worth mentioning. Especially compared to that abomination. But... I have to fix this before she can sell it.
what did the plugs look like. were they black and wet. or really white. we had a disco in the shop that needed injectors and had similar symptoms. just a thought. discos are not that common in our shop. a scantool would be a world of help to you.
Plugs were very black and dry. Except number eight which wasn't firing. I also replaced filter. Needed it, but no dice. Next up, vacuum lines need replacing, and check fuel pressure.
Well, it ran fine up til this, then I disconnected, replaced, then reconnected the plugs one at a time. So I'm sure I got them back on the right ones as I only did one at a time. Thanks for checking though. :).
If your O2 sensor has been bad for a while and your missing, it could possibly be a plugged cat. Raw fuel passing through them will kill 'em quickly. A quick and easy way is to run your rig after dark until everything is nice and warm, then look at your exhaust manifold. Any orange color there, and your cats are toast.
Gotta jump in on this one. Some years ago we had ford truck that acted the same way... long story short it ended up being a plugged Cat... almost completely plugged up, so the engine couldn't run much faster, then a really fast idle. The reason I remember it, is we figured it out after it burnt every exhaust valve, so the head had to be reworked. Find a way to unbolt the exhaust, just before the cat and try that. If you can't unbolt just the cat, then unbolt the exhaust from the manafold. DON'T run your motor like that very long, especially if it is very cold out side as you don't want to risk any valve damage... but you should be able to run the engine long enough to determine if your problem is a plugged exhaust. By the way if the cat breaks up inside, it can plug up the muffler too.
I am surprized that you don't have any CEL codes.:confused:
Good luck.
PookieBear,
Since this is your thread, will you please ask a moderator to move this to the new Land Rover section here on IH8MUD. This is not 80-Series tech.
Thanks,
-B-
what a great forum
nobody even gives gives you hard time for asking questions about a rover
at least you drive a superior vehicle
I think only rappers:cool: and trustafarians:grinpimp: drive rovers nowadays:D
Oh sorry guys. :). It was the fuel pump. Long story short... Landrover part- $500.00. I got a similar GM one for $75.00 and jury rigged a bit. Runs great. :).
Beowulf- Sorry, I didn't even know we had a Land Rover forum. Thanks guys.
