th350 ?s
i have the chance to buy a 1988 chev 1/2 ton 2wd van with a tbi 350 and a th350 (i guess?) will these fit in my 76 fj40 or do i need a 4x4 tranny? if it will fit, what adapter should i get for the tcase? what about motor mounts and tranny support. i like cheap. also i only have a 2.5" lift so the rear driveline should be ok, right?
thanks for your help!
re:turbo 350?
it should fit fine, might be tight around front drive shaft. i think the 2wd tranny is ok but check out www.advanceadapters.com for more info, they sell the adapter and have a lot of info on swaps and can send a catolog to you for free. good luck!
