I have a 64-ish FJ40 with a SB350/TH350 mated to the stock 3spd case with a Downey adapter. Bought my rig on the cheap set up this way with no front driveshaft. The clearance between the flange and trans is way too tight for the stock yoke. The flange currently on the front output looks pretty butchered, and has a different hole pattern than the stock one. Anyone have any input on what would work best to hook up the front shaft? Also, my trans leaks fluid into the t-case. Any input on replacing the output shaft seal? While I have things apart I have a '73 FJ55 t-case I'd like to swap in as I have heard it's stronger than the earlier version.
New to the forum, its really nice to find a group where you don't have to explain " no, it's not a j**p "
Thanks in advance!
Thanks in advance!
