Testing rear diff fjz80
St louis
Question is when meshing the rear wheels, just turn them.till they lock up?
Inspect the differential lock operation. (1) Jack up the vehicle then start the engine. (2) (3) Put the transfer shift lever on the L position. When the Diff. lock control switch is set to the RR position, the indicator light (rear side) is turned on. Differential lock is applied to the rear wheel at this time. If the gears of the differential lock system are not meshed, the indicator light remains blinking, so rotate the tires to mesh the gear.
