Terminals keep turning green....why?
Pacific Northwest
So all of my battery terminals keep turning green...... I use baking soda about once a week now to clean them up. If I don't drive her the next day I have to switch to the 2nd battery to give her a jump. The 2nd battery is also weak which is the dedicated start battery. I brought home a charger tonight from work and even on the lowest 2 amp setting water boils out of the battery. Are both batteries toast? The start battery is probably 3 years old, and the house battery(costco marine) is a year old. I drive on a ton of washboard type roads. I had the engine out this summer for pm of the head gasket up--she was apart for about 3 months--could this have done the batteries in?
Also according to the voltage meter on the dash juice is being pumped out when driving.
Wow sounds like a real problem.
Maybe have the batteries tested , remove the terminals and clean them good with a wire brush (or like)
do the baking soda again (flush well) and put some petroleum jelly on all connections.
ken
Time for the Odyssey/Optima battery install.
Green terminals
If you haven't already i would clean the entire battery or batteries with baking soda,then i would put some lube on terminals after cleaning the posts and ends of cables with a wire brush. Also you may want to check the cables as well and check for discoloration in the wire if they are i'd replace them.
So I have a marine charging system currently to manage the batteries...... Going to a gel type is certainly an option. I have constantly cleaned these with baking soda, and lubed the terminals with di-electric grease. I was watching the batteries charging today and I think the green is coming from the gases venting when charging......my battery tie down also turns white in about a week. Maybe the sealed gel type would solve this problem. Going to have to make a U.S. run if this is the case.....down here in Mexico one goes for about $300.
Also I did not have this problem until the engine was out for pm...... i wonder if I have a short........
I can actually hear my house battery(everything except starting) sizzle while parked in the garage.
