Wonder if it would drain the battery way down if it was really cold out and you had it cranked up? I'm sure semi trucks have about 10 times the capacity as the standard LC set up.
A few years back we used a Coleman Catalytic Heater. It generated quite a bit of heat. It was 17°F outside. Inside it must have been close to 32°F.
They are about $40 and a single propane canister lasts over 12 hours.
Regards
Alvaro
If you look at the zodi, the way it brings hot air in to the tent is some cheap dryer duct and a 12 volt computer fan. so why not use this heater out side the tent and do the same thing. CPU fan prolly use less power too
Regards
Alvaro
