Temporary fix for windshield leak?
Carpinteria, CA
Has anyone used any kind of silicone or urethane sealer to seal up the leaks in their windshield for a temporary fix? I have a leak at about the midway point of the DS of windshield. I was hoping there is a solution to keep the water out until I get a chance to replace the gasket. Also, is there anyway to know if the windshield is original or factory glass?
Thanks,
Paul
Factory glass will say either Toyota or something else (forget now) that indicates it was made in Japan. Aftermarket will say PPG, etc. Look at your side windows for the makers mark and compare it to the windshield. Are you sure it is coming from the windshield? One temp fix is to try to peel up the outside rubber gasket where it meets the window with a plastic tool of some sort and put some urethane adhesive/sealant in between the rubber and the glass; very hard to do by yourself, almost need three hands (or better, a helper).
I did this as well about a month ago - light rains and the carpet was still dry. Then we got pounded w/ 2" of rain on Sunday and unfortunately I have it ripped apart drying as I type...
I'm going big-time with the caulking gun as soon as it's dry enough to work on. :bang:
I had the same leaks on both sides of the windsheild about 2 years ago. So I went around the whole windshield and used about 2 tubes of the Permatex Black ATV silicone between the glass and rubber seal and the metal and rubber (just to make sure).
rodi_1985_58948011
