Recently I replaced my instrument cluster due to a malfunctioning odometer as well as problems with my gauges. Although the fuel gauge worked, apparently the built-in resistor that feeds the oil and temp gauge had failed, resulting in no readings on those gauges.
So, with the replacement cluster installed the temp gauge was acting weird. With the key turned on the gauge pegs to the hot side. After about 10 minutes of driving, it slowly dropped to below the cold mark. I knew I wasn’t overheating as I checked the radiator hoses with a laser temp gun. Everything was at normal temperatures. After checking and rechecking all my wiring and fuses I gambled on getting a new sending unit from SOR.
Once installed the gauge now works correctly...starts at cold and slowly moves to the corresponding temp mark.
