I perfromed RT's temp gauge mod this past week and finally got it buttoned upo and went for a drive to the lake. Thought all was going well as it was pegged cold on start up then slowly started to creep up. I stopped for gas and while it was ideling i noticed the gauge stopped a little below middle, figured this was a more "accurate" reading.
Get back on the road and about 5 miles later notice the gauge is what im going to call "resetting" it self to cold. I say reseting because it didn't fall down to cold, it went violently back to cold, not a slow movement.
The next dance of the needle was raising from cold to a little below middle then reset back to cold, never staying in the middle or higher for longer than a few seconds. At this point i know i screwed something up and will be pulling out the dash again
but would like to know what to look for. I double and triple checked that i put the right resistor in the right spot, unless one is bad. Unlike diodes, Resistors are non-directional right? Also i did order two sets of resistors JIC.
Any ideas are appreciated
but would like to know what to look for. I double and triple checked that i put the right resistor in the right spot, unless one is bad. Unlike diodes, Resistors are non-directional right? Also i did order two sets of resistors JIC.Any ideas are appreciated
