Temp Gauge Mod done....running hot???
Los Angeles
Got the gauge modified last night, threw it in today and took it for a spin. I let it warm almost all the way up in the driveway to see how the needle moved on a cold start. Then I hit the road, nothing too long, maybe 10 miles. I immediately noticed the needle was looking high. It would dip slightly when driving, but after taking my foot of the gas it would climb back up right away.
The pic below is after the drive, sitting in my driveway idling in Park. I tried to take the pic from drivers perspective, just closer. If your curious, the CEL is code 71 EGR.
SO is this normal? Referencing RavenTai's write up this needle position puts me between 189 - 217 degrees. Center being 189 and bottom of red being 217.
I'm pretty sure I'm running hot. This bothers me since I've flushed my coolant system and replaced with T red and distilled h2o...in addition to butt loads of other baselining (the only thing left is brake fluid flush)
It is still hard to tell exactly what temp you are at, plus the angle of the photo.
but around 190 seems pretty par for normal running temp and according to your scale, it seems to be about there.
i'm not going to mess w/ my temp gauge- I already look at the temps way too much! ;P
Seems normal to me as well. Mine hovers around there. I am getting the ScanGuage soon so that I will have two points of reference for checking coolant temp
190 seems fine to me
After the RT temp guge mod mine hovers just above the quarter mark and has never gotten above halfway.
Buck Buchanan
Wow-great minds think alike. I was just playing with a Scangauge and my modded temp gauge today, hoping to use the scangauge to calibrate my temp gauge. Trick-T (Tom) helped me do the mod a couple of weeks ago, and then lent me the scan gauge yesterday. So this data is courtesy of him.
The very bottom of the factory gauge was 145
Steady cruise at 75 mph freeway was 181-183 which is lower than I thought. That's close to mid range on the factory gauge.
Up a long grade with heavy throttle, I got it to 192 which was just a bit above the midpoint of the modded gauge.
Where yours is showing, is hotter than mine ever got, assuming the same resisters were used modding the gauge. I'd try and borrow a scan gauge and see what the temps really are.
I'm digging that scan gauge, and have to get one of my own.
I'm very curious to know what the scan gauge tells you once you get it set up. I'm guestimating that my gauge is at 200 degrees or just below right now...assuming a linear progression from 189 to 217. Let me know what you find out.
I'm guessing its substantially higher than 190. If you read the mod reference, 189 is center and 217 is bottom of red. I'm about 1/3 between center and bottom of red, or 199'ish
My scangauge temp averages about 190..if you have an extra $160, scangauges are cool.
1994 is OBDI, no scan gauge unfortunately....
Ok, so you have 145 at very bottom, RavenTai's mod lists 150.
You have 181 to 192 as the middle range which is also a little low compared to RavenTai since he has 189 as the center, but your truck is definitely cooling itself nicely!
Yes, I think mine is hotter than yours should ever be! If I'm right, mine is just below 200 degrees. On your scale since you seem to be a bit cooler my temp would be even hotter, maybe 205, yikes!
nah man, I'm not 190, thats the problem. Center should be 190, I'm quite a bit above center.
The angle isnt of any significance, its nearly identical to how you'd read it from a driving position plus I compared it against some other straight on pics I took and its accurate. But here's another pic just for reference
If that were my gauge the scangauge would usually read right around 195-198 there. I used the vishy-dale resistors, if you used cheaper resistors with lower tolerances your results may be different (although I suspect with the given errors introduced across the entire signal path, your margin of error is different)
Either way, I'd consider that slightly hot. What are outdoor temps in western LA running right now, and are you using the AC? Have you R&R'd the fan clutch recently?
Technically I believe the thermostat doesn't open fully until ~200, but still I don't like seeing more than 195.
Andy,
I hope you have the Scangauge hooked up at DV so we can compare in exact same conditions.
I am usually at 190 and go upwards around 205+ on those freeway grades. Before the engine heat builds up, I can be in the high 180's but not for long.
Brad,
Is your coolant fresh?
Also, is it possible that there is a slight variance on where the needle is at? So you could be absolutely normal and not know it, for example.
Yes, I'm guessing I'm at 198-200. I used the exact ones used in the mod so I dont think thats an issue. What do you mean about the "entire signal path" and "margin of error is different"?
Temps today were in the 60's, maybe 70. Nope, no AC, I've only had the truck since November so I havent used it yet.
If the truck is running 200 degrees the fan clutch is on my short list of "to do's" along with a radiator flush...:frown:
Andy,
Brad,
Yep, coolant was flushed when I bought the truck less than 2,000 miles ago (on Dec 8th to be exact). Mr T red and distilled water.
I was thinking there might be a variance too, but others with a '94 have done this mod with success and not had a variance. Unless of course I have other issues causing a variance.
I wouldn't be too concerned about where the needle is. You have the right idea about swapping the fan clutch. Since it gets warm out your way you may also consider changing the fan clutch fluid to a slightly heavier weight, I hear traffic is a bear in LA.
I haven't done RT's gauge mod because I went right to a stand alone unit. With a new radiator (< 1 year, corroded fins) and fan clutch with ~8,000 cst silicone fluid my gauge usually reads around 175*-180* unless I'm really working it.
I'm not concerned about doing any immediate damage to the engine at this temp, but I'd like it down in the middle just so theres more time between normal and "oh crap".
What kind of outside temps when you're at 175-180? I was definitely thinking of using the thicker oil for a new fan clutch. There's only so many items I can afford to work on at any one time, so the new fan clutch got shelved last go around ($112), will get done now though!
Do the fan clutch (if it's original you're almost certainly going to see a change) and see what's what.
I mean that your temp sensor might be slightly out of spec, or mine might be, or both. Either way no two trucks are the same and with the variances in everything (including soldering, the needle's operation, etc) it is likely that my 195*F isn't yours. It's ballpark though, and you aren't destroying your engine but you are slightly on the hot side.
My money is on the clutch. Replace it and maybe swap it to 6k cst oil (I did) and see where you stand.
...including soldering
Hmmm, the solder on one joint was fugly because the copper on the board peeled back.
I'm starting to get upset at myself for not measuring the resistance before I put the gauge back in the truck....:bang: sometimes I'm so stupid it drives me crazy, just lazy man
