Temp Control on Air Conditioner
Vicksburg MS
It appears that whatever I have the Temp set at when the vehicle is cranked is the only temp it will blow.
So if its at 70 when I cut it off it will only blow at 70 the next time its cranked no matter how you adjust it, up or down.
If I need hot defrost I must crank it and turn it up to "hot" then cut it back off then crank it again.
Thoughts?
