Techron treatment = rough cold idle and code 26?
DirtScaresMe
Trouble Maker
Mammoth Lakes, CA
Website
facebook.com
I live in the mountains, it frequently gets single digits at night. I'm 1/4 a tank into a techron additive and the cold idle has been rough on this tank. Once I get going everything is okay, and idle is fine warm.
Got a CEL with code 26 (mixture constantly too rich). Not sure if this happens sometime with techron treatment and I just need to roll through it or if this is a real thing and time to operate.
Any maintenance done to it? EGR, 02 sensors, cats can all play a part with a 26. Mine years ago was cleared simply with a EGR modulator. (blue vs green top... or was it the other way around?) anyway... more details....
In the last ~1000 miles:
  • I put a sn/dork/el on, I eyeballed everything and it looks good.
  • I put a new throttle body hose (big ass 3" one, OEM, hose clamps look good).
  • Changed the oil, I had to disconnect the steering pump reservoir thing because the last a****** torqued the s*** out of the filter.
  • Knuckle / inner axle job, driver's side.
  • New Interstate battery.
  • Subwoofer... would love if this caused my cel.
It seemed to happen pretty suddenly and has gotten much worse. Normally it purs like a kitten and within ~20 miles (small town, that's like 5 trips) it's gotten really gross at missing idle and dancing around. I eyeballed the lower oxygen sensor and it's connected at least. I don't know where the top one is.
Planning on grabbing some carb cleaner and spraying around looking for a leak in a vacuum hose maybe?
Well I'll update this for anyone else. Cliff notes: problem vanished.
So this morning I took notes. About 25f outside.
  • Starts up 1200 RPM, everything is great, although CEL is on.
  • Drops to 1100 RPM, gets a little grumbly.
  • I popped it into neutral just to experiment, made no difference, back to park.
  • Slowed down 1000 RPM, grumbly.
  • It would hang between 600 and 400, dipping every second or so, pretty much perfect rhythm.
  • I revved it to 3000 (zero grumbles) and took my foot off, dropped low, got really grumbly again.
So I drive to the hardware store to get a 3/8 extension to pull my plugs. I park at the hardware store, CEL is off, all rough idle is gone, and purrs like a kitten.
So:
a) I can't prove it's the Techron treatment, it might be something I knocked around while fighting with the oil filter.
b) I have a funny feeling this problem will come back because nothing is easy.
