Technical question.
Can anyone out there answer a question for me. On a early 2F say 75-77, what size are the bolts that hold the alt bracket to the engine? I think they are M10x20 or 25 and 1.25 pitch with a 14mm head. Am I correct? Also what size is the bolt that holds the alt in tension on the sloted bracket, M8x15 with 1.25 pitch with a 12mm head or a M6?
Thanks
Josh
Thanks
Josh
Yes you are correct on the alt. bracket mounting bolt...
"M8x15 with 1.25 pitch with a 12mm head"- this is the bolt for the alt tensioner bracket, NOT M6
Good luck!
-Steve
