On the S-10 master cylinder that I purchased to do a disc brake conversion, one of the outlets (the front one) is larger diameter than the rear one. On another master cylinder, the rear outlet is larger.
1- Is the larger outlet supposed to go to the disc brakes? Or the drums? If I have it hooked up wrong, will it matter?
2- I'm using the same size brake line with an adapter. Should have I used a larger diameter line? What problems will that cause?
3- For future reference, is there a standard routing for the larger line in a mixed system? (discs/drums)
I ended up not doing the S-10 conversion, but used another master cylinder, which I believe is the Corvette.
