Tech info on Marlin Crawler's new 1985-1988 W56 Short Throw Kits
BigMike
Supporting Vendor
Where Rock Crawling Started Fresno, CA
Website
marlincrawler.com
We have just released our One Piece Short Throw Shifter Kit for the 4WD 1985-1988 W56 platform.
Kit includes USA-made billet aluminum base, pre-installed custom-made high quality stainless steel serviceable pivot bolts, modified & reconditioned Toyota shift handle, new Toyota shift boot, four captured-washer shift handle retainer plate bolts, and of course our popular Heavy Duty Red Shift Seat and Socket included!
Tech info on this new kit:
  • Eliminates the hard to find and leak-prone thick factory rubber gasket and it's six bolt spacers
    • The thickness of the rubber has been calculated into the height of the base
  • Leak-free One-piece Design
    • Replaces 8 factory parts with our one base
  • Serviceable Stainless Steel Pivot Bolts
    • If the pivots in a stock base go bad, the entire base must be thrown away. Our design provides pivots that may be serviced at any time.
  • Shift Handle Retainer Plate traps pivot bolts in place preventing critical failure
    • If our loctited pivot bolt ever becomes loose, it can only move millimeters until it interferes with the handle's retainer plate. The very worst case scenario would just be a slightly loose shift handle rather than the shift handle flying out while you are trying to speed shift (something you'll be enjoying immensely).
  • Transmission flange bolts remain in the stock location for ease of access
    • The old way to reduce the throw was to slap a 1" spacer between the stock base and transmission flange. This required bolts that are 1" longer than stock. If you don't have a body lift, it can be a real pain in the ass trying to get these longer bolts in or out due to interference with the floorboard.
  • Includes original modified Toyota Shift Handle (we'll need your old handle back)
  • Includes the World's BEST USA-made Heavy Duty Seat and Socket
    • The short throw magnifies just how great our H.D. Seat and Socket are. You've gotta check it out for yourself.
  • Low Profile Design for floorboard clearance
    • As mentioned, the old 1" spacer approach raised the entire shift base up 1" which causes interference in some cases and is particularly tricky to install with flat-belly (raised drivetrain setups)
  • Made in USA from USA Billet Aluminum
    • Way stronger than the stock cast part it replaces. Enough said.
For more info, see 1985 W56-A kits and 1986-1988 W56-B kits.
So, what do you guys think? It will maintain the same 40% shift handle pattern reduction as our other G52/G54/G58 and R150F/R151F kits, reducing both forward-to-back and side-to-side movements.
I'll keep this updated with any questions you might have and will also post additional pictures of the complete kit soon.
Happy Crawl'n from Marlin Crawler!
Regards,
BigMike
Awesome, looking forward to the next series which should cover my 90 pickup. That and a turbo clutch conversion will round out my next project nicely.
jynx,
The larger Turbo clutch is a great upgrade. W56C/D/E is next on the list!
Trevor,
Sorry but unfortunately no, the 2WD W-series transmission have a different bolt pattern and also an offset/extension to the base (with a different, offset shifter design beneath the pivot).
Regards,
BigMike
jynx,
Regards,
BigMike
Any idea on timing?
Thanks
We are still working on our installer, but for the meantime, here come some install pictures from a customer :D
1. First remove your interior boot to expose your stock base.
2. Remove the stock handle & base and clean & degrease the surface to prepare for it's new silicone seal.
3. Install our new Short Throw base with our included Red Heavy Duty Shift Seat!
4. Install our new Short Throw Shift Handle with our Heavy Duty Shift Socket and new Toyota boot pre-installed and you're done!
The entire job should take a first-time installer approximately 20 minutes to complete.
Step 5. Get out and enjoy your new shifter!
Here is a comparison photo from this customer. you can see that before he had to remove the shift knob from his Crawl Box shifter due to it contacting his shift handle in 4th gear.
Now with our new Short Throw Kit installed, you can see how much extra clearance there is in the same 4th gear position, and he was able to finally re-install his Crawl Box shift knob:
Happy Gear Jam'n!
Regards,
BigMike
Nice. I just put a Marlin W56A in my 85 4Runner last September. Working great so far. I may have to get one of these short throws for it.
I know you were already asked about a short throw for a 2WD W series. I would really love that for my 89 pickup. Any chances that will happen?
Awesome. I'm running our Short Throw on my W56-A-HD and I love it :D
It's possible but won't come around until we've built all 4WD applications first!
Regards,
BigMike
