Tdc?
Edmond, OK
I'm having trouble finding the timing mark so that I can adjust my valves. What should I be looking for? Or is there another way to determine when #1 is at TDC? Thanks for all your help.
Brian
Right above the starter is a small cover, remove it and bump the starter until you see a line, there is also a ball, but TDC is the line.
There you go.
Ed
I have been looking at the space above the starter that has a point on it and haven't had any luck finding the line. I did find a spot where I think TDC is and it appears to have a notch in the flywheel maybe about a half inch or so long. Is this the correct spot? The rotor on the dizzy points just before the #4 spark plug on the #3 side, just like the great haynes manual says. I just want to make sure so I don't mess the valves up.
Thanks,
Brian
you are looking for a small line that is on the flywheel if you cant get it by
bumping the starter or dont have a remote start try this. with the truck off put the
transmission in gear with mine third gear did the trick, get one of your friends to
put down his beer and help you out, have your buddy push the car back and forth,
this will turn the flywheel everytime the truck goes forward. i marked the ball with
yellow paint so i can see it with a timing light good luck :beer: :cheers:
