TCM Codes? O/D Flashing
South Texas
Newbie, been browsing this forum for weeks. Yeah, I'm hooked. Gr8 stuff. :flipoff2:
Here's the question which I couldn't find in the FAQ or via search.
93 shifts with her usual clunk from 1st to 2nd, no issues. But, you can see acceleration is lacking from 2nd to 3rd. It'll get there, just "slowly" with normal RPM ranges, 1800 - 3000. But, if you floor it, it'll shift to 3rd at 4000 rpm, and the O/D light will begin to flash.
I pulled the "paperclip" method off and tried to pull the codes. But, here's the strange part. Once the vehicle is placed into Park, the O/D stops flashing, so, I've got no TCM code to pull.
I did have some exhaust work done around the O2 sensor before this reared it's head. Wonder if that may have something to do with it.
Also, I've been taking O/D off and just running the ECT. Runs about the same, and will do the same thing with the O/D light flashing if I engage the O/D.
Thoughts??
Thanks in advance. I'll post some pics in the next few days.
Mike
No, I wasn't aware of that. Do you know the terminals?? Same steps you'd use for ECM?? Thanks, I appreciate the response.
M
Thanks. This is the post I tried too use before.
Problem is. When I shut the engine down (even just to the "on" position) after getting the "O/D" flashing light, the light stops flashing.
So, I have nothing to reference without the O/D light on. Should I leave the engine running with the O/D light flashing and try to pull the codes? I don't want to do anything out of the "norm" and potentially screw the pooch. :cool:
Weird chit huh?
Thx for the assist on this.
M
Hmm...
The cruise control diagnostic system has something like that, where you need to pull over and retrieve the code before shutting off the vehicle, but no, I don't think you need to do that.
When trying to pull the codes, are you getting a steadily flashing O/D light? It should at least do that, even if there are no codes. Otherwise, maybe you missed a step in the test procedure: O/D button is on? Key is in ON position with engine off? Etc...
Yep. I followed the steps VERY carefully.
I just thought of 1 thing though. I really didn't push the paperclip ends REALLY deep into the DLC box.
How deep should I be pushing the ends of the paperclip in??
Again, my apologies for being new to the LC. Mutiple 4runners/Tacomas before the LC, but, never had to try and do diagnostics this way.
Thx, I appreciate a "lifers" assistance.
:cheers:
I think you can stick 'em pretty far in there without hurting anything: You need to get through all that protective goo and make sure you really are getting a connection.
Oh, and don't put too much stock in the "lifer" status. Some of us just have too much time on our hands. ;)
Cheers,
Curtis
That's correct. No O/D light flashing at all once I stop the vehicle and turn the engine off.
Semlin's post does say "turn ignition on". And my assumption on that was turning the the key to the "on" position. Not starting the vehicle.
For the paperclip connection, they just have to be touching the grounds in each of the E1 and TT holes, correct? Don't need to jammed down in there or anything?
M
I agree on the steady flash.
Think I'll shove the ends of the paperclip down a bit further this time and see if that makes a difference.
Just FYI. The O/D doesn't flash AT ALL after I stop, park and turn the engine off (still in "on" mode). Shouldn't it stay flashing, until you clear it from the fuse??
It's almost like it "only" flashes after you "push" the engine into 3rd gear. Like I said, in my original post. I can "baby it" all the way to 80MPH if I want. It's only flooring it beyond 4000 RPM does the O/D light begin to flash, and then when I stop. She's gone.
Ok, I'm starting to sound drunk here. :O) hahaha:D
Thx again CJF, appreciate the help.
M
Ok.
I'll try pushing the paperclip ends deeper into the DLC holes and see if I can't get something going here.
Thx
No CEL codes. It did flash at "normal" intervals.
She's running like a champ, ECT and O/D engaged. No issues, and smooth shifting.
Freaking Japanese Gremlins let over from WWII. :)
I appreciate the assistance.
Was going to baseline ALL the fluids this weekend.
Rotella T Syn 15-40. Not sure what is in there.
Tranny fluid is prefectly red. But, she's getting pushed out 4 qts at a time.
M
