Tcase Questions? HF2a/splitcase differences?
Ok I am thinking a splitcase will bolt onto the A440 in my 92 fj80 correct? Then the stock HF2A should bolt up to a NP203 using the Advanced Adapters Doubler plate for the Splitcase? There bolt 19spline correct and since they bolt bolt up to the A440 they should have the same boltpattern correct? I am trying to figure if I need to buy a Spitcase for a doubler setup.
The tail shaft is shorter in your tranny for the 80 series. So the spilt case will "not just bolt up". The tail shaft is designed for the HF2A is a male and female slip. The 80 series t-case(female) slides on to the 440 shaft(male). Where the splits case is built on to the 62 longer 440 shaft.
You would need the FJ62 Tranny for this to work right, or replace the out put shaft (on your 80)with the longer one from the FJ62 tranny.
The A440 transmission wouldnt be included in the setup it would be
GM TH400 or 4L80E
GM Np203 Range Box
AA Np203 to Splitcase Adapter
and either Splitcase or if it'll work early 92 non viscous HF2A
So the input shaft in the HF2A and Splitcase are the same lengths and its the transmission that have different lenght output shafts correct? They are set at the same distance from the bolt face that bolts to the transmission? Are the bolt patterns on the bolt faces the same? I guess I will probally just have to try it.
I was just wondering if anyone had tried it? I know how the splitcase bolts up to the A440, I have seen pictures, but I am not sure how the HF2A bolts up? I was thinking since they bolted to the same transmission that they would be similar, are the FJ62 & 80 A440's tailhousings different then? I am going to buy a splitcase because I figured the HF2A wouldnt bolt up to the NP203 with the adapter, but would'nt hurt to ask ya know.
